Lesser Known Classics Discussion Forum
Long 510 fuel injector pump
postman
09-26-2007 11:28:15
I had a leak at the piston cap on my fuel injector pump so I removed it to replace the rubber ring gasket.I was careful but three springs and the piston popped out (oh great).
Does anyone know the order these things go back in or have I lost some parts? I have a Long Service Manual but it doesn't show these details. Thank you
long 560 dt
12-23-2007 09:31:27
 Re: Long 510 fuel injector pump in reply to postman, 09-26-2007 11:28:15
For my series tractor manual for inside of the pump to outside list order that I think you want to know.
from bottom there will be
priming spring
piston
regulating spring
valve sleeve
sleeve plug
retaining spring
end plate with transfer pressure regulating valve
from top-is your fuel inlet connection. Hope this helps
