TractorLinks.com
Show Parts for Model:
Oliver 550 transmission oil
Doyle F
10-15-2005 12:12:15
My 1973 Oliver 550 operators manual says to mix 2.5 pints of oil additive #102 082-A with 5 gallons of 10W-30 motor oil. Is this oil additive still availabe and if so where? Is there an alternative transmission oil that can be used and if so, where can it be purchased? I would appreciate any information I could get. Thanks.
J. Schwiebert
10-15-2005 15:23:51
 Re: Oliver 550 transmission oil in reply to Doyle F, 10-15-2005 12:12:15
No additive is no longer available. I am wondering what the publication number of your manual is. I left the dealership in 1976 and we were used 80-90 gear oil at that time and had been for a few years. Don't forget there is more than one drain plug if you are changing it. Just get a 5 gallon bucket full because it takes most of it. I would also change the hydraulic filter and the oil at least once a year. A good 10W-30 API class oil for a gas engine will work in the hydraulic. so if that is the oil you use in the engine you can also use it in the hydraulic system. Questions?
Doyle F
10-15-2005 19:42:02
 Re: Oliver 550 transmission oil in reply to J. Schwiebert, 10-15-2005 15:23:51
Thanks for the response. In answer to your question, the manual I have is "Operator's Manual"Form No. 432 362 issued May 1973
