Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Vickers Vane Pump Repair
Robin Glennie
07-09-2004 11:58:39
Someone was driving our old 550 and jammed the hydraulics - now the casting on the pump is split in three places.. plus a couple of the impeller vanes shattered when they caught on the edges of the cracks.
The local dealer can't seem to find used parts, and tell me a replacement pump is very expensive.
Anyone out there have a used pump or parts thereof they can part with... or a direct source for new parts?
Thanks in advance for your help!
- Robin
07-10-2004 13:55:08
 Re: Vickers Vane Pump Repair in reply to Robin Glennie, 07-09-2004 11:58:39
I have a couple of old Vickers hydraulic pumps. Do you have a number off of your pump. Or you can call me at (316)722-4270
Robin Glennie
07-17-2004 13:58:57
 Re: Re: Vickers Vane Pump Repair in reply to Marty, 07-10-2004 13:55:08
The pump has the following stamped on it.....
V120 25 213 10
1-21 S203
The center ring is 3" square.
The pump is from a Cockshutt 550, Serial number 140603-519
Robin Glennie
07-26-2004 12:52:06
 Re: Re: Re: Vickers Vane Pump Repair in reply to Robin Glennie, 07-17-2004 13:58:57
... I should also add the center ring is 3/4 " thick. Apparently this dimension varied across several versions of the pump.
07-09-2004 18:37:59
Check your relief valves good as I've seen them stick and break these pumps. If you have a external valve check the relief in it good as this is the ones I've seen stick.
J. Schwiebert
07-09-2004 15:28:37
I am going 99% by memory but if I remember correctly the real early 550 pump is slightly different than the later ones. There will be a Vickers number stamped in the pump. Get that number and talk to a Vickers distributor. If both end housings are good you may get by vith a repair kit. Questions, send me a PM on the hartparr site. I work with a good Vickers distributor in my other occupation.
Robin Glennie
07-12-2004 15:58:09
 Re: Re: Vickers Vane Pump Repair in reply to J. Schwiebert, 07-09-2004 15:28:37
The pump is a V120. Both housings are good, although scored, so all I need is the central casting and the impeller with new vanes.
According to the excellent web page specified below, I can fix it with Cartridge kit #912058 and Seal kit #229236.
My local Motion Industries distributer can get me the seal kit, but the cartridge kit (according to them) is unavailable.
If you have a source for this hard-to-find kit I would be thrilled!
- Robin.
