Merlin the Tractor Guy
03-30-2002 04:08:08
Re: Re: Re: 2-155 Cummins repower in reply to Darren..Merlin do you know about White motors??, 03-29-2002 11:54:58
Hi, Darren! Yes, I have re-built several White/Hercules engines. They are a very smooth running diesel, and can easily make a lot of power. The major drawback to them that I see is that they tend to operate very hot under heavy loads. I have seen a lot of farmers having to remove the side panels to keep their White running cool. Many of the older Hercules engines developed loose liners, so at rebuild it is necessary to install .005" oversize liners. I did this on the last one that I rebuilt: it was not fun. I had to enlarge each cylider with a rigid hone, and it took forever! The liners must have a proper press fit, or you will have trouble. Also, since the Hercules does not have a cross-flow head, you might want to consider either a straight pipe for the exhaust, or a very low restriction muffler that will reduce the operating temperature. Another thing, which would look good if properly done, would be to have some louvres punched into the side panels. Along with the factory stripes, they would look right at home. Oliver did this on the 2050/2150 by using mesh side panels. I really like the 2-135/2-155 tractors, but I think that for the long haul, it is better to invest in a Cummins engine for one of these. As long as your loads are reasonable, horsepower should not be a problem, as true horsepower is only measured against a load. Good luck on the re-paint: it will look sharp! Merlin
