Now for my 1550 hydraulid question
Mike(NEOhio)
Location
Newbury, Ohio
I only use my right side remote for my MoCo, single acting. Sometimes when I hit the lever to lift I'll have to do it two or three times before it rises. I know my pump is weak so I checked the pressure and got 1500-1600, should be 2000 to 2100. I added a washer to the relief valve, about .070, and it came up another 200 psi. Question is should I add more or replace the spring? Going to try adding. If it comes up more I should know whether it's the spring or the pump. Am I on the right track?
