Ficks from Indiana
Several months ago I posted on here that I was having problems with my rear hydraulic pump attached to my 1365 fora 1510 loader. This pump has actually been blowing the rear seal and putting the hydraulic fluid from the loader reservoir.
I have finally found an overhaul kit for my pump but I am a little hesitant in using it if there is something else going on. Most that I talk to says the pump is bad and needs worked on. I'm looking for opinions before I install this very expensive overhaul kit.
Thanks in advance.
Thanks in advance.
