I rebuilt a standard 88 for my brother in law, he said when they parked it the gas had to be shut off or gas would run out of the carb a minute later, I rebuilt his carb when I rebuilt the engine, and it still did it, I took the carb apart and found a crack, I put another carb I had and got it tuned in and it did the same. I took it apart and nothing was wrong, float set correct, I took the carb off my 88 and put that one on, turned the gas on and instantly was running out. I pull my 88 and have a fuel pump on it and never have an issue. I m at my wits end on my brother in laws. I m thinking it has to be something about his fuel line tank or sediment bowl causing it to do it to 3 different carbs
I m very sorry for the length of this post I am just out of ideas
