1550 runs too slow
super99
The new to me 1550 doesnt run fast enough, doesnt
quite get to pto speed on the tach
This is wide open. Where do I adjust engine speed?
Do I adjust here or
Or here? Thanks,Chris
I have 2 1550's. This one runs much slower than the other one with a new tach, I can tell just by listening when its running.
OP manual explains how to set the carb linkages but it'a a bit tricky to me.
The lever behind the spring should be adjusted to be parallel with the crankshaft centerline with the throttle at wide open. Then use the screw on the end of the spring (not in the pic) to set the high idle speed.
Wish my tach looked as nice as yours.
