Oliver 77 stroker motor
MHfreeman
Looking for info on a stroker motor for a 77 was looking at using farmall c rods but how do you modify them for the oiling system on these tractors thanks in advance.
You can either get your crank drilled, (my preference), or take your C rods to a shop along with a 77 rod for comparison, and have the C rods, (and bearings), drilled to receive the sprayed in oil as Waukesha designed it. gm
