Front axle brace
rrlund
I mentioned the other day in somebody else's post that I thought the wide front with the brace on top was wider than the one with it underneath. I had it backwards. Here's what it says in an article about the 1950T in the May/June HPOC magazine. I'm quoting, so don't shoot the messenger.
''The 1950T Row Crop could be ordered with five different front axles to meet the needs of the farmer......What doesn't seem to be widely known is that Oliver also had the narrow tread adjustable wide front axle that allowed for wheel spacing needed in narrow row crops. This axle can be visually identified, as the wishbone support is attached to the top of the axle tube on the narrow tread, and on the bottom of the regular tread.''
I would have thought it would have been the other way around since the one on the bottom came later as did narrow row crops, but I measured the ones that I have and the center tube is a little shorter on the one that has the brace on top.
So what did you come up with for numbers? I measured my 1800. 42 1/2 same as 770 and my 3 88s. The axle off my 1550 34 with the wishbone underneath. It has been bout 20 years but I read somewhere of an optional narrow wide front. Figgerd thats what this must be. Rear wheels were set so narrow somebody torched the floor boards to get the tires in.
I had 42 on the one underneath, 41 on the one over the top. The over the top is on an early 1600 though. What I don't know is, did they make a narrower one later on that was narrower? The small wide front on my 66 is narrower than that, but it slips my mind what it measures off the top of my head. It was somewhere in the 30s.
