White 1370 - Help to identify part of the cooling system
Looking for help to identify a plastic piece below the cooling system thermostat. The piece is white (yellowed) plastic - photo and diagram attached.
I need to replace it because coolant is pouring out. It could be a gasket, but I m not up to dismantling it, so I need to get the part and gasket and take it to the mechanic.
I would call it the ''thermostat bypass tube, White just calls it a ''pipe'', and there's a serial number break.
9
31-2900135
Seal
10
677212A
Pipe (S/N 000001 - 721487)
10
31-2902109
Pipe (S/N 721488 -)
11
677200A
GASKET
11
31-2902106
Gasket (S/N 721488 -)
I'd call Rick's Ag Parts and see if he has that tube. I just changed the water pump on mine a few weeks ago. They
told me the gaskets should be in the box with it but they weren't. I went to the auto parts store and got package
with four sheets of different gasket materials and made my own. It wasn't hard to do. I don't blame you for not
messing with it yourself. It literally took all day. We started taking the loader off at about 10:30 and had it
back together around quarter to five.
