Need help!! 1900 PTO bearing.
mogman
I am not sure why this did not post the first time. I am in need of a PTO output bearing/seal for a 1900 sn 114xxx
Found it!
88107, 207RR3, JD9301, seems to be a common driveshaft center support for early GM vehicles, the local JD dealer has the JD9301 in stock!
The bearing had spun in the housing, if I could find the housing at a reasonable cost I would buy one.
Thank God for Deere!!!---Tee
I suppose it's about the same as my 1850, but not sure.
Anyways, if the bearing housing is relatively small........
Remove it, place on a milling machine, bolt it down loosely, and find center with a coax indicator(or you can sweep it with a regular indicator), tighten the bolts, then index the part to the mill table so that you can put it back in the exact location. Witness marks, or bars clamped to the table so's the thing will only go back on the table one way.
If it's cast iron, which is likely(?), then either braze buildup inside the bore.........or high Nickel rods to weld it up.
Bronze will machine easier, Nickel machines a bit hard.
Pop 'er back on the table, measure the od of your new bearing, and use a boring head to machine to size. Very light press fit ought to be adequate, unless you can tell it never was a press fit by the geometry of the part. If a good bore required the bearing to be driven out, you're looking at a press fit.
Or................save yourself a lot of drama, and hope you can find a good used one.
Thanks, I have a replacement coming, yes same as the 1800.
I thought about trying to build it up and machine it but the replacement was reasonable enough and re-cutting the snap ring groove would be a challenge for me..
Unfortunately the closest Agco dealer is about an hour and a half away, I guess I should be grateful one is that close.
Funny Victoria Oliver is now a Kubota dealer but kept the name...
