Oliver 550 front loader, can I use the internal pump
Bornfree1966
New User
Hello all, I'm new to all things Oliver, but I am a seasoned machinist/millwright with Hotrods and Harleys in my stable, and now a 1958 Oliver 550 with a front loader.
I have started the restoration with the first thing opening up the hydraulic / transmission housing, finding blown seals and a twisted impeller shaft in the Vickers 5-GPM hydraulic pump. Now with all new internals for that pump I am questioning if it's the right pump to continue using for my front loader....
I know Oliver used external front mounted pumps when Loaders/Backhoes were factory installed, but I have seen many 550's with aftermarket loaders such as mine is (Agratec), and wondering if most of those are using the internal pump as mine is.
Hoping for your experience and suggestions!
Thanks in advance for your time and knowledge.
Chris
Yes you can. They're not as fast, but they work fine. They're ''live'' so they'll work even if the clutch pedal is
depressed.
Hello and Thank you very much for your advice, I will be continuing with the rebuild as it was, using the internal pump.
Cheers'
Chris
