1550 Transmission
super99
The new to me 1550 has a knock in the transmission in all gears on the right side of both neutrals, R2, 4, R1 and 2. I suspect one gear has a bad tooth causing the noise. Has anyone been into the transmission on one of these? How far down do you have to go to get to the right gear, I'm guessing it's clear at the bottom. Any thoughts?? Thanks, Chris
I've been into mine. Once when I got it just to check the overall condition then to change out a broken left shifter shaft. You can see down in there pretty good. I'd suggest draining it, jack up one wheel and roll through all the gears while you watch with a good light. Mine has an intermitten rumble somewhere. Not a noise and doesn't happen all the time. Can't figure it out.
