560 Cockshutt head gasket
AndrewJ
Does anyone know a source for a head gasket and upper head gasket set for a 1961 560 Cockshutt.. I can t read the engine tag but I think it s a 4-270 Perkins in it??
Maibach Tractor in Ohio shows one gasket left 330-939-4192. They should also have the valve cover gasket if you need too?
Wayne
(quoted from post at 21:35:58 04/01/23) Maibach Tractor in Ohio shows one gasket left 330-939-4192. They should also have the valve cover gasket if you need too?
Wayne
I need both! I ll give them a call Monday .. what part number did they show for the head gasket and valve cover ?
Again, I say call Phil. Have your serial number as the parts book shows two part numbers for the head gasket.
just finished head gasket repair on cockshutt 550 spuresised to find hyead needed milling. had not been
hot hercules g198
YES, WE have the head gaskets, valve cover gaskets and complete head sets on stock here for the PERKINS engines used in COCKSHUTT TRACTORS...PLUS many more parts for PERKINS ENGINES and COCKSHUTT BUILT TRACTORS.
Phil Heisey
215-256-651
scootergmc,
THANK YOU for posting me as a source.
YES WE have the HEAD GASKETS & HEAD PARTS ON STOCK for the PERKINS ENGINES used in COCKSHUTT BUILT TRACTORS..............PLUS many more parts!
Phil
