replace front camshaft gears 88 std
replacing because governor shaft broke and governor gear damaged the camshaft gear. where can i get replacement parts ? camshaft gear ,crankshaft gear and governor bushing for block as well as thrust washer for governor gear??? thanks
I have the gears and maybe the trust washer I would try Korves they might have everything you need I am in Canada
I have not done this since 1976 and the bushing and thrust washer were replaced then by superceeded parts before that. Like I said send me an e-mail. J.
