570super to 570 Cockshutt injection pump swap
American Bosch PSB pump? They will interchange IF the injection line ends are the same at the pump. I've seen both male and female hydraulic head outlets which must match the lines
used.
(quoted from post at 23:35:36 03/31/23) American Bosch PSB pump? They will interchange IF the injection line ends are the same at the pump. I've seen both male and female hydraulic head outlets which must match the lines
used.
Yes Psb6a pumps.. the tag on the governor housing is the same on both but the tag in the hydraulic head is missing off of the one so didn t know for sure if they are the same.. different displacement engines so I wasn t sure if the pumps could be swapped.
(quoted from post at 01:38:43 04/01/23) Dont worry about the head tag, the LINE outlets need to
match.
The lines fit they are the same.. so would the 570 super just use larger injector tips?
(quoted from post at 02:56:12 04/01/23) I'll have to look at an old CAV injector list but I'll bet the tips are the same.
I d be curious to know if you have time to check that out some time.
I was thinking with the 570 super being a larger displacement it would require more fuel somehow so something would be different.
Bullfeathers, both PSB pumps work the same. Only change is SOME engines used different line end fittings at the pump head. I've seen both types on pumps I've had in for
repair.
