145 Workhorse
Just wondering if any one has adjusted the oil pressure. Installed new rings and pistons along with new bearings. Engine runs fine and quiet but has low oil pressure when at operating temperature.
I should have checked the bearing to crankshaft clearance more closely. Engine still has a lighter oil in it, will change it shortly to straight 30. Can I adjust the oil pressure to get the desired pressure by putting more pressure on the poppet valve and spring located on the front, left-hand side of the engine? We use this machine about 30 hours per year.
