I am having a hydraulic leak on my 1650 that is coming from the tube that houses the 3 point lift control shaft. It protrudes from the RH side, under the seat and is coupled to the 3 point lever with a double threaded linkage.
How do I fix this leak? Is there a seal on the 3 point lift control shaft? How would I fix it and how big of a job is it. Looking at the tech manual, but it is not very helpful.
Thanks,
Trace
Thanks,
Trace
