Orchard tractor for rrlund
ArleninOr
Here is the pics of the 885 orchard tractor.
Did they rotate the differentials one bolt hole or is it just the small tires that make it sit so low? Nelson LeCount bought an Oliver 600 out in California that sits low. The differentials are rotated one hole on that one.
I should have saved a picture of the 885 orchard that was on CL here a week or two ago. That one had one orchard fender on it and what looked like an old Case 430 fender or something on the other side.
Looking at the rear wheel in relation to the fenders it looks like all that's been done is to put on a set of smaller diameter wheels,looks like the standard issue DB fenders to me too.
Should have gotten a pic of the rear end. It is narrower than a standard 885 with lift arms that are not straight but have a bend is them. Differentials are also rotated. Front axle is more like a 770/880 with shorter spindles. Should have parked it alongside my regular 885 to show the differences. Saw the one you were talking about and it was a standard model with one orchard fender and an early case fender on the other side. Will get a picture of the rear and post it tonight.
Spindles are a lot shorter than my 885 regular tractor. Fenders are a little too. Running boards are a little wider to accommodate the narrow rear end. Will try to get some measurements.
