880 countershaft nut
Olliejunkie
The nut on my countershaft is loose. What do you use to hold it? Looks like I might be able to get a offset wrench or a combination wrench in there but I do not have one and don't want to buy one if it won't work. Also how do you keep them tight? Lock tight? Thank you Paul
A box end wrench. The nuts were staked in place. Lock it in 2 gears to hold the shaft, get the nut tight and stake in place Never seen one come loose.
