TractorLinks.com
Show Parts for Model:
Oliver 1650 3point stuck
Jason Seekamp
07-11-2018 07:40:05
I Have a Oliver 1650 and the 3 point is stuck in the up position. I heard that there is a pin or rod stuck causing the pressure to not release. Is that a tough job to fix. Any tips before I crack it open and or part numer for that pin. Thanks
J. Schwiebert
07-12-2018 05:14:36
 Re: Oliver 1650 3point stuck in reply to Jason Seekamp, 07-11-2018 07:40:05
I can give you a few Send me an e-mail with phone number. The problem is easy to get to. J.
Jason Seekamp
07-12-2018 11:33:43
 Re: Oliver 1650 3point stuck in reply to J. Schwiebert, 07-12-2018 05:14:36
Need your email J
J. Schwiebert
07-12-2018 17:56:40
 Re: Oliver 1650 3point stuck in reply to Jason Seekamp, 07-12-2018 11:33:43
Should be here.
NYOlivers
07-12-2018 06:16:32
J. Could you please give me a call when you have a chance? I sent an Email with number. Thank you
Mike(NEOhio)
07-11-2018 11:23:15
May need to reset the link to the draft sensing lever. Or take the pin out and rotate it all the way to the rear and see if it will lower. Check the lift arm free play, too.
