Nebraska Tests
Riverslim
Hadn't tried to check specs on a few models in a long time. Couldn't find "off brands' #$#@^%$ like Oliver, MM. Couldn't find Farmall either, was wondering how WD9 compared to 99.
Farmall WD9 as per the neb test list I have is 51HP and the Oliver 99 is 62HP
You will have to find the year of the test, this link does have the 990 however.
https://digitalcommons.unl.edu/tractormuseumlit/index.16.html#year_1956
If you go to tractordata.com there is usually a link to the Nebraska test usually in the "power" section, it will be a link to a PDF file of the test. You will probably not find the WD-9 under Farmall as I think they were badged as "International" not Farmall, red guys will know.
