TractorLinks.com
Show Parts for Model:
Engine blocks
stilts
06-11-2018 16:35:10
I have two 49 model 77 Row Crops. Both with a cracked engine blocks between the cylinder walls. I want to know will a block for a Super 77 fit and what is the actual difference between the two? The block is stamped 185220 /M100 on both of the engines I have.
stilts
06-12-2018 20:46:55
 Re: Engine blocks in reply to stilts, 06-11-2018 16:35:10
I don't know the history on these engine. I will keep that in mine on these restors.
Thanks for reply.
stilts
06-12-2018 20:42:37
Thanks
derwen1959
06-12-2018 15:37:04
could the cracks be caused by continual overheating
Tramway Guy
06-12-2018 13:44:35
No need to do anything special. Adhere to the standard torque sequence and values and it should be fine.
stilts
06-12-2018 11:43:42
The cracks appear to be at top on both engine blocks. Will it seal off enough with just good head gaskets,or is there something I should do to insure a good seal?
I haven't got the pistons out on one of them yet.
J. Schwiebert
06-11-2018 16:53:38
Are the cracks between the cylinders at the top of the block or the bottom of the block? Cracks at the top of the block will not hurt anything. Yes a Super block will interchange. My e-mail should be open if you have more questions. J.
Olliejunkie
06-11-2018 16:50:47
Cracks in the upper cylinder wall is pretty common and is probably ok. I'm sure someone else will chime in with more info.
