1650 oliver
Bison2010
This tractor has a Holley dis. On it that plastic piece on plate as the hole wore out where points sit in Is this part available?thanks
Like centerplate said. We had the same issue on our 1650. Hard
starting and if it did it ran horrible. Put electronic ignition
on it and never looked back. Runs great !
Do a search on this forum and you should find a description of how to get by with a worn plate. You can screw it down so it doesn't move and cause problems. If I remember correctly, the ability of the plate to move only affects idling.
Vacuum advance only affects idling in this situation. Centrifugal advance would be unaffected and tractor works fine under load.
