update on 1655
hoghollow
Purchased this 1655 gas wide front about month ago. Noticed water leaking out of waterpump seep hole so replaced pump. Also replaced one tie rod and narrowed front end (both sides moved very easy with just a come-a-long for pressure). Put about 3 hrs on it cutting hay with 489 haybine today. Tractor ran fine over under worked very good. Think I did all right gave $2900 Did notice oil leak at rear of valve cover. Also changed eng and over under oil and filters Do not know how to post pictures but happy with tractor.
