Late last summer I had issue where the three point arms wouldn't operate after just being used days earlier. I looked into dip stick area and there was no oil. I refilled it and started the tractor only to see it go low again. I thought maybe it has to be fuller so once again I topped it off only to see the fluid drain again when I started the tractor. I thought the issue was the pan having a hole in it so I stopped any further work on the tractor knowing I had an issue I didn't have the time to correct. The oil I did know had gone below into the transmission. So this year I am now dealing with the issue along with my uncle. We have taken the hydraulic section off the tractor and see nothing out of the norm. The pan looks in real good shape so I can't figure out where the fluid when to get in to the transmission.
So here are my questions
Did the pump blow and I can't see it? If so where do I look?
Is there anything I should be looking at besides the pump that could be the issue?
What am I missing here?
Any help on this would be great. I an a novice at this and could use the advice, thanks.
