Oliver 1650 input shaft
Bloomy34
New User
Last fall when I had the hydra power out I had a lot of play on the input shaft of the transmission. I changed the seal on the input shaft and when I had the seal holder off there was a lot of shims under it and I took all but one out and it tightened the shaft up a lot. But I?m getting ready to pull the motor again to put a different hydra power in it and was wondering if I should investigate deeper? Could it be the bearings on the input shaft?
