TractorLinks.com
Show Parts for Model:
Oliver 1650 input shaft
Bloomy34
05-14-2018 15:23:44
Last fall when I had the hydra power out I had a lot of play on the input shaft of the transmission. I changed the seal on the input shaft and when I had the seal holder off there was a lot of shims under it and I took all but one out and it tightened the shaft up a lot. But Iím getting ready to pull the motor again to put a different hydra power in it and was wondering if I should investigate deeper? Could it be the bearings on the input shaft?
J. Schwiebert
05-15-2018 04:59:10
 Re: Oliver 1650 input shaft in reply to Bloomy34, 05-14-2018 15:23:44
Yes it could be the bearings. Also check the sealing ring on the shaft!.
Bloomy34
05-15-2018 09:53:47
 Re: Oliver 1650 input shaft in reply to J. Schwiebert, 05-15-2018 04:59:10
Can the bearings be changed by removing the hydraulic unit?
J. Schwiebert
05-16-2018 17:21:51
 Re: Oliver 1650 input shaft in reply to Bloomy34, 05-15-2018 09:53:47
Yes
