880 injection pump
hunt
I have put a super 88 pump on an 880 and it has a flutter at wide open throttle when the rpm was turned up to meet spec for an 880. Will the high speed style delivery valve setup from the 880 pump fit the super 88 pump? I really do not want to pull them unless they can be swapped.
That flutter was a problem. There were several things they did to correct that. Now I need to recall my memory. E-mail is open. J.
