Oliver 1600 and 1650 sheet metal
Bloomy34
New User
Does anyone know if the side panels for the hood are the same between a 1600 and a 1650? I?m talking about the long ones with the That the White panel bolts to with the Oliver name and model.
Bloomy34, The side panel that I had was different.
The hood will be different if the 1650 has a dry element air cleaner. I think those side panels will fit,but you need the brackets that bolt to the tank and radiator support off the 1600. Somebody correct me if I'm wrong. My 1550 seems to be one of the few with the 3 piece sides and I know those brackets are different than the ones on the 1600.
Randy, I've seen the three piece sides mentioned here a lot. Are they three separate pieces or three pieces spot welded together like the one in the picture? Mine is like that.
Three separate pieces. There's a vertical strip by the radiator,a small horizontal strip at the lower rear and the big piece that the spear is on. Just imagine cutting that one piece where the joints are. There are just finger nuts holding the top piece on and it tips out and lifts off.
