Oliver plow - looking for 12" moldboards
Curtis
I'm looking for NC225-12 moldboards for a 102 Plowmaster plow. Can anyone recommend a source? I need two. Can be new or good used. I've checked my local dealer and a number of aftermarket sources and can't seem to find any new 12" moldboards in the 225 (or 425/625 style for later plows). Any leads would be appreciated.
You could try a 14" moldboard. I would bet the frog bolt holes and the curvature is the same and the only difference is the board is slightly taller and slightly longer. Maybe the brace bolt hole is moved, maybe it is the same. You could then trim down the 14" to match the profile of the 12". I was looking for NOS Moline moldboards last fall and was tripping over NOS Oliver 225 boards.
(quoted from post at 18:36:52 05/03/18) Where are you located that you have the 225 bottoms? Never seen one!
J, I’m located in SE PA, but the plow came from NY. I’m not sure how common the 225 bottoms were in that area. The frame doesn’t show much wear or abuse, but the bottoms were heavily worn (apparently from rocky/gravel soil condition) including the rear edge of the moldboards which is worn to a sharp serrated edge.
