Adding a belt pulley
Nick167
The 77 I just bought doesn’t have a belt pulley drive and I would to add one what all is involved to do so? It’s a gas tractor by the way. Thanks!
If it needs a clutch do it before you install the pulley as it has to be removed to install the clutch!. You need to fold the instrument panel over and of course you need to remove the long PTO shaft.
(quoted from post at 13:38:55 05/01/18) If it needs a clutch do it before you install the pulley as it has to be removed to install the clutch!. You need to fold the instrument panel over and of course you need to remove the long PTO shaft.
Thanks J I may go ahead and change it while it’s easy to get to
