560 Cockshutt diesel wiring
I picked up the 560 diesel yesterday. runs decent. but it won't start with the key. have to cross the solenoid with a screw driver. generator has no wires hooked up to it. there are 2 wires hanging down near the generator. The light switch won't turn, but I will try to free it up.
I bought an IT Manual for it, but it has nothing in it for wiring the tractor also the fuel gauge isn't working.
Does anyone have the wiring diagram that they could share with me. which posts. go from ignition to starter and generator relay etc. I see the generator has a couple of letters by the posts, one is an A.
I would really appreciate it.
John
I think I have one in the operators manual. I will also need tractor serial number as if I remember right there are 2 depending on serial number. I will need to mail it to you and I also need your e-mail as I can attach it to an e-mail. My e-mail is open. J.
Hi thanks for your reply.. I looked for the serial number. where do I find ir. I think somewhere I read on the right side of the frame, but for some reason I can't seem to find it.
my email is
[email protected]
(quoted from post at 02:22:37 04/29/18) I think I have one in the operators manual. I will also need tractor serial number as if I remember right there are 2 depending on serial number. I will need to mail it to you and I also need your e-mail as I can attach it to an e-mail. My e-mail is open. J.
Tried to email you but it isn't there. Anyway I looked all over for a number on the right side, the only number I can find is one right behind the generator stamped into the top of the frame. It says, CR1467.
John
You are one lucky duck. A very late 1962 modell. Some lists don?t even show the 62 models. It is the highest serial number 62 number I have seen. I have twon consecutive serial
number 61 560s. Love all the 500 series.
(quoted from post at 15:08:03 04/30/18) You are one lucky duck. A very late 1962 modell. Some lists don?t even show the 62 models. It is the highest serial number 62 number I have seen. I have twon consecutive serial
Well thank you. I didn't know what I was buying. The guy didn't know what year it was and I bought it sight unseen. it starts very quick. and seems to run very nice. needs a lot of TLC.. For some reason the wiring is mostly all disconnected . no wires from switch to solenoid or generator. I have to cross the solenoid with a screw driver to start it. I don't like that standing in front of the rear wheel starting it.
1761595
