Oliver super 77 main bearings
Does anyone have a cross reference for Dura bond main bearings for a super 77.I don't think they are available anymore.Need to find some others that match. Thanks
OK, I may be able to find a set of main bearings. I will need some more information from you...E-mail is open. Bottom right,
Classic view.
Wayne
It appears that this site has them in stock. The price they show isn't too out of line either.
(quoted from post at 14:46:48 04/28/18) I sent you an e-mail. Did you receive it? J.
I think I have part of my problem figured out.The old bearings I took out were ink stamped on the back as .010.Some were hard to read. Now I know the size of the bearing.The problem now is they look like new but still the oil pressure isn't where it should be. I have checked everything I know of.Even put in new relief valve and spring.Checked the oil filter base and small washer is in place as it should be.Guess I will try a different oil pump to see if that helps.Oil pressure is around 30 when cold and drops to about 4 after about 20 minutes of running.I am using 15w40 oil.
Before you pull the pump make up a bearing leak detector and see where your leak is. send me an e-mail for more details. Normally it is the bypass in the filter. J.
