Oliver 550 transmission problem
When I put my 550 in neutral and take my foot off the clutch it will move forward very slightly and the engine loads a little. It's like something in the rear end really isn't in neutral. It is also really hard to roll by hand with the engine off and the transmission in neutral. Any thoughts on what the problem could be?
May have a bearing going bad on one of the speed gears of the transmission, causing it to try to turn the main shaft. See if you can get the high and low range between gears and see if it still does it. There isn't a real neutral in the high low, but my Super 55 will do it.
