Where to get Oliver Parts .
LeoinMI
A friend of mine just bought a 1942 Oliver 60 Standard with a hydraulic belly blade. It is a cool machine and operates well. He just wondered where to get parts for this tractor when the need arises. He may need some rear wheel rims in the future. The present ones are home made and have large tires on them. Any information is appreciated. I am a Ford guy,so I could not help him much.
This site has some aftermarket items. I buy mostly from Maibach Tractor in Creston OH. 800-808-9934. They KNOW old Oliver stuff. I'm in S.E. Michigan and usually get my parts next day ground. They also salavge tractors so they might have something that is NLA new from their yard.
First thing to do when you get any antique tractor is to subscribe to the magazine for that marque. In this case, Oliver Heritage. Most sources of reproduction parts run ads every month, plus you can put wants and needs in for possible response by individuals.
Oliver Heritage magazine
Thank you guys for the info. I will pass it on to my friend. His tractor seems to be kinda rare in as much the hydraulic belly blade is factory made by Oliver. The tractor was a County Road Commission tractor and was used to grade the gravel roads in Newaygo County, Michigan.The tractor is complete and he has replaced some hoses,but everything works as it should. I.ll try and post some pictures of it in the future. Thanks again.
(quoted from post at 16:28:01 04/26/18) Thank you guys for the info. I will pass it on to my friend. His tractor seems to be kinda rare in as much the hydraulic belly blade is factory made by Oliver. The tractor was a County Road Commission tractor and was used to grade the gravel roads in Newaygo County, Michigan.The tractor is complete and he has replaced some hoses,but everything works as it should. I.ll try and post some pictures of it in the future. Thanks again.
I would love to have one of them mowers. Lucky guy.
For parts I like Korves. They are great to deal with. Old school. Maibach is good too. Rims may not be as easy to find but they're out there. Mine is 7 lug which makes it harder. If his is a standard that might make it easier.
