Oliver 550 PTO Clutch Assembly Broken
wallmonte
New User
Hi,
I am new to owning a tractor in general and recently acquired an Oliver 550. The PTO would not engage and so I started pulling the tractor apart to see what was going. I am not sure what the specific part is called, but the plate in the pto clutch assembly that pushes up against the clutch disk is snapped into two pieces. I can not seem to find a replacement part online.
Does anyone know where I can find a replacement or can I fix the part I have?
Thank you in advance for your help!
Do you have a good clutch shop nearby. If so just take the whole clutch in and have it done right. If the pressure plate is broken chances are
there are other parts that are junk now to. We have all ours done by South Bend clutch if you can't find any place local.
Where are you located? We need a serial number too as there were changes in those clutches. Kent will have used parts + some people I know will maybe have new old stock yet. Do you have a shop manual? My e-mail should be open. J.
I am in Leander TX and I do not have a shop manual yet.
It will take me a few days to get back out to where the tractor is parked and find the serial number. However, my version has 6 fiber disk and 5 steal plates if that helps identify it.
Thank you!
I have the pressure plate you're needing, plus any other clutch
parts --My email's open or you can call me---Thanks
Kent Gordon
Palestine, TX
903 729 8349
