GSR
Which of the Oliver gas engines will bolt into a Super 77? Would a 16XX to 17XX series bolt in? Thanks
The mounting bolt pattern in the tub is the same for both the short and long blocks. You can put the longer block into the tub, you just have to modify or replace other components to make it work. You making a puller, or a work tractor? If making a puller you don't need to worry about the long pto shaft. I'm sure once you reveal your intentions you will get more correct info.
