Super 55 valve
JL Ray
My tractor has the secondary valve down between your leg. I need to tap another pressure and return port for another valve. Can I do this?
I guess I'll give it a shot. The factory remote valve is not between your legs but rather on the right side just below the 3 point quadrant lever. If you search the archives there are pictures showing the pressure and return ports located under the valve. If you buy an aftermarket 2 spool valve you should be able to pipe it up. If you do have a factory remote valve I'm sure you would be able to sell it for enough money to purchase an aftermarket 2 spool valve.
Thank you for the answer. I understand. I'll move the factory valve over to my other 55 and fab a mount up for a three valve stack. I'm think I'll mount them just to the right of the steering wheel. I never was fond of the factory location. I have 3 valve bodies to choose from with one being a four valve stack. All harvested off fork trucks. Ill probably use a 3 valve one which came off a Cat since I know it was just factory rebuilt before we scraped out the truck. In hind site I sure wish I would have harvested the tilt cylinders off those trucks.
