1650 -265 gas engine help
jasinpa
have a burnt valve in a 1650 gas (265) engine boy the prices ive seen for these valves. then i see the 283 engine the valves are fairly cheap why such a price difference ? will the 283 valves work in the 265? or can someone tell me a good after market part number for the 265 valves , theres no way a valve should cost that much. also is the 265 ind. waukesha engine use the same valves & engine parts as the Oliver engine?
We;; the valve in your 1650 was a valve made from STELLITE because of the problems they had with valves made from conventional materials. The same is true for the valve seat inserts. My e-mail is open. Send me a reply and I will explain it.
