550 3pt lift arms
super99
I have one of the 550's running. The 3 pt arms were with it but not hooked on. The problem is the holes for the pins in the rockshaft don't line up. On the right side, the pin will start, but not go all the way thru. On the left side, the holes aren't even close. It looks like one side of the clevis is bent at an angle. Can I just heat it enough to bend it without causing a problem, not sure if it's cast or steel. I could probably drill it out large enough to get the pin to go thru but really don't want to go that route if possible. Thanks, Chris
Here are a few pictures of the problem. How much are you asking for a pair? E-mail is open.
Those got sprung somehow. Looks like they lifted something heavy with the pins half way out.
