Oliver 1800
Does tractor have a 2speed hydra power? If it does make sure it shifts ok and fluid looks good and clean. If the head gasket was replaced check all engine fluids make sure no oil in water and vise versa. I would check all fluids. Make sure the trans shifts into all gears and pto works. What condition is the tractor in?
I will look it over the best i can. Exterior looks good. Was concerned of possible head crack? It is a hydra power. Don't know where to check that fluid. Want to add to my hay fleet.Thanks
What year is the tractor? There were 3 versions of the 1800 made. A-B-C there are differences between all three, you can check the serial number on tractordata.com if your not sure. To check hydra-power fluid there is a dipstick/breather on it. It looks the same as the dipstick/breather for the hydraulic fluid. If standing on the left side of the tractor it is on by hydra power unit. Is it a narrow or wide front? It would be hard to tell if head was cracked without checking when it was apart.
Did the owner keep the old head gasket. Make sure you get the serial number and if the engine has one or two oil filters. How long ago was the head gasket changed? Was the head retorqued. Ah just send me an e-mail. J.
