oliver 880 diesel driveshaft
WORNOUT
Just purchased used oliver 880 diesel working good, previous owner claims he has had trouble with the drive shaft from engine to trans, shaft seems to move back and forth coming out of spline. Is this common problem? what prevents shaft from moving ou of spline. Thanks
There should be a set screw in the coupler where it hooks to the transmission input shaft. Is that in there?
I've made a couple of those "keeper bolts." All it took was a regular thread 3/8s bolt by 3/4 long, a bench grinder, some patience, and a little care. gm
