TractorLinks.com
Show Parts for Model:
66 rocker arm assembly
Olliejunkie
03-06-2018 13:37:56
I changed the pan and rocker cover on an engine I bought. One of the rocker studs came out. I put it back in with a lock washer but when I had it all buttoned up I found a copper washer. Is it supposed to go on the rocker hold down?
Also under the pan there is a M62 stamped. Anyone know what that means?
Olliejunkie
03-06-2018 19:23:36
 Re: 66 rocker arm assembly in reply to Olliejunkie, 03-06-2018 13:37:56
Yep. A friend looked it up and found that's where it went. I only found 1. I have always used flat washers but when I put it on there wasn't enough room so all it got is nuts.
Still curious about the M62 stamp.
Dieseltech
03-06-2018 18:46:01
I'd think the copper washer would be on the valve cover outside. That's where MH Continental engines use copper washers.
Gary Mitchell
03-07-2018 08:43:06
 Re: 66 rocker arm assembly in reply to Dieseltech, 03-06-2018 18:46:01
I second the "outside of valve cover" copper flat washers. gm
