6342 Rollover Plow
2510Paul
There is a 6342 Rollover Plow on CL in WI. Are there wear parts available for those yet?
The AGCO site doesn't even seem to recognize Oliver anymore. Is that true?
Your comments would be appreciated.
Paul
White/Oliver tillage is in the New Idea section. Use the "browse books" drop down menu in the upper left of the opening page.
Thanks for your comments. Maybe I am looking in the wrong places but I have having trouble finding replacement wear parts. The AGCO site has the plow as New Idea as you said. The parts catalog has the non-wear parts but no wear parts listed. Obviously that is in a different catalog but I have yet to find it.
Thanks.
Paul
You are looking at the PLOW model numbers, you need to look at the BOTTOMS as plows could be fitted with several different bottoms depending on soils, plowing speed wanted etc. It most likely has 619 bottoms, but there are others. Look on the back side of your existing moldboards the bottom type should be stamped there. There are exceptions to the rule, but generally 619 were for 4-1/2 mph, and 919 were for 6-1/2mph plowing speed. Raydex bottoms are designed to plow correctly at 1/2 of cutting width for depth (ie. 14" cut bottom at 7" deep, 16" bottom at 8" deep). I'd have to do some digging to find it but one of the older pieces of literature showed diagrams of why the Raydex bottoms fractured the soil so well.
