1750 Hydraulic pressure
TASO
I checked my 1750 hydraulic pressure since it seemed weak. I found out it was 1600. It should be about 2000 plus. Can the pressure be adjusted to be as it should be or is the pump going bad? The tractor has about 7300 hours on it and the pump is likely original.
Thanks.
My 1550 had only 500 when I got it. That pump is obsolete but it turned out to be just blown seals. I found a seal kit and now it's at or close to the 2000 it needs. You could also have a weak spring on the relief valve or an internal leak. With those hours, though it's likely the pump.
