3 Point 3X18 Plow?
1970-1655
Some time back there was an Oliver 3 point mounted plow on the photo classifieds with 3x18's. What model would that be and how hard are they to find? I swapped over from 16.9x34 weather cracked tires to 18.4x34 radial tires so I got to thinking about the plow too long and it is sold.
348 and 6342 (two way) were the only fully mounted available in 16-18". The other 3XX plows were 14-16". Basic rule of thumb for Oliver/White if model number starts with a 3 then fully mounted, starts with a 4 full trailer, starts with a 5 semi-mounted. If you could get by with a semi-mount try Brian Block 734-674-7458 he had a Ford painted White semi mount 3x18.
