Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
6 Volt Positive Ground
60 Fan
02-11-2018 08:50:57
Question, 65 plus years ago, My Father used a 66 for daily chores only in winter time. (Read here short times running in sub zero weather) Always had good luck with starting and battery was always up.
During these winters he some how set or wired the generator to a full charge in order to not have problems with short run times. Can anyone tell me specifically what he jumpered or bypassed to accomplish this full charge during severe cold only? When spring came along he set it back to being charged with regulator as normal. Thanks.
gary66
02-12-2018 22:24:56
 Re: 6 Volt Positive Ground in reply to 60 Fan, 02-11-2018 08:50:57
what's a full charge and what's a normal charge? Why even have both. Just trying to understand.
rrlund
02-11-2018 09:49:32
Remove the wire from the BAT terminal on the voltage regulator and connect it along with the existing wire to the L terminal.
Mike(NEOhio)
02-11-2018 09:39:57
Most if not all of the old 6v systems used the light switch. In was low charge, one click out for high charge, two clicks for lights if you had them. There was a small coil of resistance wire on the switch body mounted on studs. The switch body was grounded. When on high charge the switch bypassed the coil internally which is the same as grounding the field wire.
J. Schwiebert
02-11-2018 09:55:45
 Re: 6 Volt Positive Ground in reply to Mike(NEOhio), 02-11-2018 09:39:57
Once Oliver got to the Fleetline series they used a voltage regulator to control the rate of charge. The 60 and70 tractors used the light switch. Also the 66 had a 3 brush generator and by moving the third brush you can change generator output.
Sprint 6
02-11-2018 09:20:59
My Super 55 owners manual has the procedure, but I don't remember how to do it now. Mine was a family tractor that was wired for full charge when I got it. Took me awhile to figure out why it was boiling batteries when I started mowing 8 acres regularly.
leroy in ne
02-11-2018 09:05:47
Delco generator if you ground the field lead they go to full charge, only controlled by generator output level.
neil grant
02-11-2018 13:42:28
 Re: 6 Volt Positive Ground in reply to leroy in ne, 02-11-2018 09:05:47
That is the right answer. Most 6 volt auto lites on cases, Cockshutts and Massey’s work the same way. If you need even more, you can move the 3rd brush. Grounding the field will give you full output. Best for short runs as an all day run will possibly make the armature get hot and throw it’s solder, not to mention boiling the water out of the battery.
