oliver super 88 engine block
Yes the blocks are the same. Are you going from gas to diesel or the other way? You need to change some items to convert from one to the other.
my previous engine is a diesel I want to keep it a diesel I will use all my diesel parts from previous engine it is easier to find a gas bare block thanks ill keep looking for a block this was my first post a will work at getting good at this
(quoted from post at 12:29:26 02/10/18) my previous engine is a diesel I want to keep it a diesel I will use all my diesel parts from previous engine it is easier to find a gas bare block thanks ill keep looking for a block this was my first post a will work at getting good at this
Match the casting numbers behind the starter.
